Ir para o conteúdo principal
couldn't access the bios?
Hello everyone i am trying to fix my acer aspire v5-431 but i couldn't access my bios to format it i have tried everything else mention over previous threads but nothing worked for me..!!All it does is starts with acer logo and after a while suddenly gives blue screen death issue.i have attached few images any help would be highly appreciated thank you!
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
Have you tried pressing F2 on start up?
Esta resposta foi útil?
Pontuação 1
Hello
Try to remove the battery for 30 mn then put it back switch on and see if is okay
Pontuação 0
2 comentários:
you mean bios battery or power batter?
por
I have done that , but still the same problem
por
This answer by Michaeleangelo for similar problem but for V5-471, helped me to resolve. Just short two pins under G2101 (clear CMOS) to restart BIOS, you will find it on motherboard under RAM closer to laptop edge. If not helped then try to update your BIOS to your latest firmware BIOS firmwares official Acer support. Then I was able to invoke BIOS by pressing F2 at the start of laptop.
Pontuação 0
Adicionar a sua resposta
Krishna Shakya será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 1,343
