Ir para o conteúdo principal
Not Sure if I should just replace my screen help?
so I work at starbucks and I'm around a lot of milk I had my phone in my apron and got some milk in the charging port not a lot but enough to make my phone screen start twitching and flashing white, I dried it and then used my hair dryer when I got home, and now my screen works off and on I cant use my touch screen at all to scroll or tap any apps to open, but the rest of my phone works , my screen is lit normally, siri and my home and power button work, I still get calls and texts like normal but my touch screen isn't working so I cant answer or reply, I did some reading but I'm not sure if I just need a digitizer or just my whole screen replaced ? or if I need to just get a new phone
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hello
You need new screen definitely
Good luck
Esta resposta foi útil?
Pontuação 0
1 comentário:
And get someone to check the inside of the phone for liquid damage.
por
Adicionar a sua resposta
Danesha Price será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 47
