Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
Home Button Connector Getting Extremely Hot
Hi! I was recently repairing an iPhone 7 screen and everything seemed to check out correctly. I had safely transferred the home button so that it would not lose functionality, and it did not give me notification about the home button no longer working when I booted up the phone with the new screen. However, it was not working.
I disconnected the home button and reconnected it, and the connector became extremely hot and it burned my finger. It was too hot to touch and you could feel some heat coming off of it from the top of the screen.
I tried a second new screen just in case, and it gave me the same results. There is no damage to the connector and nothing in the way of it.
Has anyone else had this issue before? I have researched and have seen people who have had the same issue with the iPhone 6S home buttons in the past, but I have not found anyone talking about this with the 7. Any input is appreciated. Thanks!
-Taylor @Batteries Plus
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Taylor, The screens that you purchased may have the wrong resistance put on them causing the home button to get hot ive experienced this issue before i switched my screen supplier and the problem didnt persist.
I highly reccommend trying a new supplier
Stephen T.
CPR Cellphone Repair.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Jeremy Wiles será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 829
