Ir para o conteúdo principal
The Dell Inspiron 15 (N5050) is a mid-sized laptop manufactured by Dell, Inc. that operates on Windows 7. The laptop features include a WLED HD display screen and a max supported memory of 8 GB.
The laptop (Dell Inspiron n5050) is dead
Hi,
I've been off and kept the warm laptop in the bag (definitely a mistake) for few days. When I came back from holidays, my laptop wouldn't power on. I can't see the power LED glowing despite plugging power cable. The pressing the start-up for 30 sec doesn't work. I've taken out batteries and added back again but no luck. The laptop is complete dead.
I've replaced the power cable. The online research show it might be the battery issue, but I've seen many laptops running on the power cable when the battery is damaged.
What can be an issue? Shall I replace a battery?
Please help, my laptop is full of important document and photos.
Thanks
Esta é uma boa pergunta?
Pontuação 1
2 comentários
When it boots up do the power LEDs light up? (I know the do't stay on, but do they light up at all)
por
I've not seen power LEDs light up at all, actually laptop even not boots up, it's completely dead.
por
Adicionar um comentário
1 resposta
Solução escolhida
If you remove the battery and plug in the charger it should work. If it doesn't It's a greater issue than just the battery.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Shrikant Thakare será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 622
