Ir para o conteúdo principal
Second generation Internet streaming device by Google optimized for high definintion video. Released in October 2015. Model NC2-6A5.
6 Perguntas Visualizar todos
Why my chromecast overheating and reboot?
My chromecast 2015 start to reboot when it became too hot (it's berely untouchable). When I put a fan direct to the chromecast the problem doesn't show and the chromecast itself was a lot more cooler. There is a definitive solution for this overheating problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
When mine over heats i add a ice pack with a towel so that moister won't affect it. Hope it helps and then im able o run it for a longer period of time. still plan on moding this like adding a larger heat sink and a new case for it.
Esta resposta foi útil?
Pontuação 1
I would try contacting google first for your options, if nothing hits your fancy there, either buy a new chromecast or open it up and re-paste, note that if it has been on contact with liquid, even near steam, water will have ingressed inside and that's the cause of the overheating. something shorting (even a little) inside on that board will cause havoc and overheating.
Pontuação 0
1 comentário:
I have my Chromecast hooked up in my van & I already installed a heatsink & it still gets hot shuts off, not as much with a fan on it. now my refrigerator is about two ft below my TV so I'm going to try this. Getting an extension cable for my hdmi (about 3ft.) Plugging it in between the TV & the Chromecast & setting the Chromecast inside my refrigerator to cool it down. I will post the results. Oh I will also put it in a plastic bag to keep any moisture out.
por
Hello! My suggestion would either be to place the Chromecast in an open air environment where air can freely circulate on its own, or buy a purpose built Chromecast heatsink like this one: https://www.amazon.com/Stream-Cooler-Rou...
Pontuação 0
Adicionar a sua resposta
David Rapisarda será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 43
Duração total: 5,583
