Ir para o conteúdo principal
O aspirador iRobot Roomba 655 Pet Series, fabricado em 2012. Exclusivo da Costco.
Side brush isn't working.
The side brush isn't working anymore. I've replaced the entire side brush unit and it will do a .25 revolution once it starts cleaning then the side brush will not work. I've striped it down and cleaned everything that could be cleaned. I am At a loss here no idea what's up and I-robot told me to buy a new one when I called the help line.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Did you solved the problem? I have the exact same thing, replaced the module, still not spinning :-(
por
Adicionar um comentário
1 resposta
Solução escolhida
@bobo006, Ben, If you have already replaced the side brush motor and still not working, check the wires and connector for being, loose/damaged/corroded/check the connector with DVOM to ensure power is getting to the motor and make necessary repairs if defect found. If motor has not been replaced perhaps consider replacing motor. 1st link below is a guide to replacing side brush motor and 2nd link will get you inside to inspect the mother board for loose/damaged/burnt components. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Substituição do motor da escova lateral do iRobot Roomba 655 Pet Series
Substituição da placa-mãe do iRobot Roomba 655 Pet Series
Imagem de iRobot Roomba 655 Pet Series Placa-mãe
Guia
Nível de dificuldade:
Difícil
2 - 3 hours
Imagem de iRobot Roomba 655 Pet Series Motor da escova lateral
Guia
Moderado
10 - 15 minutes
Esta resposta foi útil?
Pontuação 2
2 comentários:
My roomba side brush remains on. This happened after my roomba got wet. What can I do?
por
Be sure the central screw on the brush is not too tight. Even though you can turn it with your fingers Roomba will detect a TANGLE if its too tight and shut it down.
por
Adicionar a sua resposta
Ben será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 4,371
