Ir para o conteúdo principal
Pergunta encerrada
pushing on the dial no longer works (ie play/stop)
you can still adjust the volume with the dial, but you cannot press play, stop or forward. You can also dock the ipod nano and still play or stop using the remote, just not on the actual ipod dial.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
While the click wheel is definitely the first part to replace, Apple made it very difficult to do so on these iPods. The click wheel is sandwiched between the front panel and a metal plate that is glued onto the front panel. If you are replacing just the click wheel, you will need some intense adhesive to make sure the metal plate adheres to the front panel. Otherwise, pushing the buttons results in the whole click wheel recessing into the iPod (we've seen this happen with this repair attempt).
Otherwise, replace the front panel with one that includes the click wheel!
Esta resposta foi útil?
Pontuação 0
It sounds like you will need a new click wheel in order to fix this problem. You can purchase one of theses off of ebay from a US seller for no more than 10 USD.
3rd Gen Click Wheel:
http://cgi.ebay.com/iPod-3rd-Gen-Nano-cl...
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 1,658
