Ir para o conteúdo principal
The third generation of the Apple iPad, released on March 16, 2012. Full 4G and Wi-Fi model repair guides. Repairs require heat and careful prying. Model numbers: A1416, A1430, and A1403.
Re-installing On/off switch bracket
Ipad 3rd generation
I am battling to re-install the bracket that hold the on/off switch (behind the rear camera.)
Is the bracket all side same side?
I just cannot get it to seat properly so that the switch button can operate the switch itself.
Is that bracket available as a replacement part?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
This guide will get you to it:
iPad 3 Wi-Fi Power & Volume Button Replacement.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I already followed that guide but it does not show how to replace the bracket. I have tried numerous times but just cannot get that bracket back to seat so I can screw it down. Should the switch itself go inside that oval ring from the top?
por
Adicionar a sua resposta
Toy Meyer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 85
