Ir para o conteúdo principal
Google Home voice-activated speaker, equipped with Google Assistant. Announced October 4, 2016 and released November 4, 2016.
My google home has stopped working completely
When I turn it on I get 2 vertical lights, then a cross of 4 lights, and this repeats....
It's not connecting to the internet, and not responding to any questions
This started about a week ago. For the previous 6 months it has been ok
I suspect its a software update problem. Can you help me?
Esta é uma boa pergunta?
Pontuação 10
7 comentários
Could you take some pictures of both lights?
Adicionar imagens a uma pergunta já existente
por
I have the same problem but I have no lights whatsoever on mine
por
lights turn on but alexa doesn’t speak
por
My Google Home is not working
por
Google home says it's not connected to the internet
por
Exibir mais 2 comentários
Adicionar um comentário
6 respostas
Pergunta mais útil
Each of these won’t take more than a few minutes at most, so when Google Home doesn’t respond:
Press the microphone mute button to see if Google Home was muted accidentally.
Unplug Google Home before waiting at least a minute to plug it back in.
Gently blow on both black dots on the top of Google Home, and then wipe the top with a soft and dry
Perform a factory reset by pressing and holding the microphone mute button for 15 seconds until you hear the confirmation from Google Assistant. A factory reset will clear all personal data from Google Home.
Esta resposta foi útil?
Pontuação 8
I had the same issue with my Google home.
But after updating my home address, its work like a charm. Update your as well:
Open the Google Home app on your Smartphone → Tap on the hamburgerMore settingsGoogle Account settings → Update Personal info.
If this solution does not work for you, then try some other fixes to solve Google Home not responding problem.
Pontuação 5
1 comentário:
The new google home update crashes upon setup. I have Android 4.4.2 so it "should" work. Jimmycurk@gmail.com
por
It was a software update issue. Had to reboot the whole thing and reset it…..
Pontuação 3
Chinese troep. Ik heb het probleem niet meer. Ik heb het in de vuilnis gegooid
Pontuação 1
My Google home not working
Pontuação 1
1 comentário:
Past 30days:179 not working
por
It’s not responding
Pontuação 1
1 comentário:
What do I do to get. google to respond. She stopped responding yesterday.
por
Adicionar a sua resposta
Andrew Whigham será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 18
Últimos 30 dias: 56
Ao todo: 24,835
