Ir para o conteúdo principal
Screen and vibrator button not working
After replacing the connector/jack part, my phone worked except the front speaker (up). So I reopened the phone to check what was going on and discovered that the ribbon of the front speaker/camera/sensor was damaged. I removed the whole piece and ordered a new one (not yet here) but now the whole screen doesn't work. In addition the vibrator button doesn't work either (or at least I don't get the vibrations whenever I turn it on/off)
The phone is visible on iTunes.
I wanted to know if the screen can work without the speaker/camera/sensor piece. If it's supposed to work, what could be the problem? Should I order a new screen?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I don't think you have to order any new parts. Try reseating all the connectors.
Esta resposta foi útil?
Pontuação 0
6 comentários:
I've tried it already hundred times :(
Is the screen supposed to turn on without the camera piece?
por
normally. just make sure it is the camera part and not something else
por
I completely removed this piece so yes, I'm sure it's this part... I'm willing to buy a new screen but I don't get why the vibrator button doesn't work and am worried something else broke!
por
this site tells to try this: https://www.payetteforward.com/how-to-pu... make a backup first
por
Thanks, restoration was successful but it didn't help... anyway, I don't get how this was supposed to solve the problem of the screen? The screen doesn't even have light :(
por
Exibir mais 1 comentário
Adicionar a sua resposta
Nathaniel Cohen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 65
