Ir para o conteúdo principal
Repair guides and support for the Huawei P9 Lite, released in April 2016.
74 Perguntas Visualizar todos
Why does it say its charging but its staying on 2%?
I got my Huawei a few months ago and it's been been working fine. However today the battery only charged to 67% over night and now wont charge up from 2%. I have changed the charging cable and tried charging it from my mac but the problem persists.
My mac does recognize it when it is plugged in, so I think there must be a problem with the battery. Has anyone had this problem, if so what was the issue?
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Likely because of your wall wart, or USB charger. You need one at least 5v 2.1A. Nearly any charger you get from the brands Anker or Aukey will provide this. Computer USB ports have a small output, not enough.
Hope this helps!
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thank you for your response! It took about 45mins to get to 3% and then started charging faster.
por
Adicionar a sua resposta
grottoemma será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 7
Duração total: 430
