Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
My iPhone not turning on (because the update is interrupted)
Im updating my phone Iphone 5s to be exact when the internet suddenly disconnect (No more wifi connection ) my phone suddenly turns off and not turning on what could be the possible deffect ?
I cant restore it on itunes .
Is this already a dead board ?
How can i fix this thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Connect your device to your computer, and then launch iTunes of 3uTools to see what mode your device is in.
If it is in DFU mode or recovery mode, just easy flash your device to enter Normal mode.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
I've never seen a case of this before.
The way iDevices work is that it first downloads the software, disconnects from the Internet, then applies the update.
I would first download the iPhone firmware on a computer with iTunes from
http://www.iclarified.com/750/where-to-d...
remember where you downloaded it
Then plug your phone into the computer and put your phone into DFU mode.
There will be a message if done properly that you need to restore your iphone.
On a Mac hold Option on the keyboard, and click Restore. Then choose the firmware you downloaded.
On a PC, hold the SHIFT on the keyboard, and click Restore. Then choose the firmware you downloaded.
If this does not fix your issue, you do have a non related hardware problem. This will require different troubleshooting methods.
Pontuação 2
7 comentários:
What should i download the firmware that im installing or my previous firmware ?
por
Download the latest one (I think its 10.3.2).
por
Okay thanks :)
por
Is their any possibility that the board is broken due to the failed updating of the phone ?
por
Not from a software update.
por
Exibir mais 2 comentários
You could try entering DFU mode if none of the solutions above work.
Pontuação 0
Adicionar a sua resposta
Fixie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 186
