Why has the sound stopped?
the sound has stopped all the functions are working but no sound
Esta é uma boa pergunta?
msthang332001, Make sure the Line In Switch is in the off position if not using the Auxiliary Input, make sure the line-in switch, located on the back of the system near the auxiliary cable, is in the off position. It may be a bad volume switch/connection, bad speakers/connection, possible fuse blown for internal amp. if equipped or could be a faulty amp. The guide 1st link below will help get you inside the device to check/test components. If under warranty have repaired/replaced/refund under the warranty. Last link is Crosley support page. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 19
Duração total: 293
