Ir para o conteúdo principal
HD action camera with touchscreen LCD, released October 5, 2014.
My HDMI connector is broke off inside can I fix it personally
Yes my HDMI connector went inside the GoPro use for flying drone 3dr solo for live view and it is fully loose inside rattling around more last came off the motherboard best way I can explain it can I fix that without replacing the whole motherboard or is it going to take some special skill and tools pull that one off
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
You will probably be looking at a very similar process to the one in this guide. The hdmi port itself will likely require exceptional soldering skills and the necessary tools to do so. Your best bet if you lack these skills is sending it to a local repair shop.
GoPro Hero3+ Black Edition Motherboard Replacement
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jason Yant será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 12
Ao todo: 203
