Ir para o conteúdo principal
The Samsung Galaxy Note 4 is a cellular smartphone that was released in October 2014. The Galaxy Note 4 Model Number is SM-N910, SM-N910A, SM-N910T, SM-N910V, or SM-N910R4 for American variants.
Battery overheating despite replacement
Battery overheats to around 68 C then device shuts down. Power saver does not work. I installed a custom ROM (Lineage OS 14.1) and that seems to work, it functions like a normal phone except I can't play games for long periods. Idle temps on custom ROM and set to battery saver sit L's around 42-45 C. I have tried replacing the old battery (Anker 3220mAp) with another anker battery but still the same problem. Could the sensor on the motherboard be dead or damaged? As when it says temps are 66C the phone does not feel hot at all. Even when removing the back cover to feel battery, it does not feel hot. Any ideas?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
issue still persist even with OEM battery. Going to give up on this one, sell it for parts. Thanks anyways
por
Adicionar um comentário
1 resposta
Pergunta mais útil
I recommend replacing the battery with a genuine Samsung battery.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Yeah, I ordered one on amazon, arriving tonight. Will see if that works!
por
new battery just arrived, idle temps are 45-46 C but off power saver, on power saver it sits around 41-42C
por
Adicionar a sua resposta
ameer7867 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 454
