Ir para o conteúdo principal
A compact version of the HTC One, released August 2013.
20 Perguntas Visualizar todos
bootloader is locked and I am stuck in it
it shows
locked
M4_U PUT SHIP S -O N
HBOOT-2.22.0000
OS-4.09.707.6
eMMC-BOOT 1024MB
FASTBOOT USB
<VOL UP> to previous item
<vol down> to next item
<power> to select item
BOOTLOADER
REBOOT
REBOOT BOOTLOADER
POWER DOWN
"whatever i choose it goes back to this page and i am stuck " plz help me there should be a solution for this
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
You need to register an HTC developer account and have them send you the bootloader unlock code.
https://www.htcdev.com/
http://www.htcdev.com/bootloader/
Note that you need to know how to setup and use Android ADB to unlock the bootloader.
You also need to note that your warranty is void once you unlock your bootloader.
Esta resposta foi útil?
Pontuação 0
dismantle the phone and remove the volume up and down button, try once.....if works, you need to change volume buttons.
Pontuação 0
Adicionar a sua resposta
shanaz será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 4,450
