Ir para o conteúdo principal
What Is Belkin.range? Help With belkin Extender Setup
i don't know how Buts its a brand new extender and i just did reset the extender . Can Somebody Help Me Setup the extender and what is this belkin.range that i just read on internet in order to setup the extender
Esta é uma boa pergunta?
Pontuação 0
2 comentários
What is the Model Of Your Extender ?
por
its Belkin N600 Dual-Band Wi-Fi Range Extender
por
Adicionar um comentário
3 respostas
Solução escolhida
1 Just Unbox Your Extender And Plug it to the Power outlet and turn it on .
2 Now Go to Your Computer Or Phone And Refresh The Network List , Their You Can See a Unsecured Network By The Name Of Belkin.setup . Please Connect with it
3 Once Connected it should Automatically Take you to configuration Portal . If Not than open Any Browser Like chrome , safari , Firefox Or Internet Explorer And Type Belkin official site
4 Now it Will Search For network name Around the extender Please select your Main Router Network and hit Next
5 Type the password of your main router and Tap Next . You Can Also Create New SSID (network name) and Password for Your Belkin extender if you wish .
6 if your Extender is a DUAL Band extender you Can Have Both Like 2.4 GHz and 5GHz Network .
For more details kindly visit
Setup And Configure Belkin Range Extender
Esta resposta foi útil?
Pontuação 3
Pergunta mais útil
Checkout this Simple Guide to fix and understand this Problem
Belkin.range And Belkin Extender Setup Guide
Belkin extender is an plug and play device .
unbox the extender and plug to the power
connect with belkin.setup on any of your device and open Belkin.range
follow the onscreen instruction and get it working
Thanks
Pontuação 4
Since we dont know your range extender, just simply google "how to set up Belkin (insert your model number here) range extender"
That will give you the instructions how to do it.
http://www.belkin.com/us/support-article...
Pontuação 2
Adicionar a sua resposta
Annie Jackson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 898
