Ir para o conteúdo principal
Informações de reparo sobre discos rígidos. Discos rígidos são dispositivos de armazenamento de dados magnéticos. Eles são usados na maioria dos desktops, laptops e servidores devido ao seu baixo custo e alta densidade de dados.
How to remove a Stripped Screw from pcb.
Hi, i have 2.5'' hdd with a torx (T6) screw on the pcb that from the force it's turned into a round hole.
I have used the rubber band method but still no luck.Also i cannot use a heat gun cause the microchips may get loose.
I must try at all cost not to damage the pcb.
Here is some images.
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
@pydev, Nick, Hardly looks like the head of a screw any more. Does not appear enough material left to cut a slot in it so I recommend you carefully drill the head off using a wee bit bigger metal bit (larger then the threaded O.D. of screw) in a power drill, remove the board and hopefully there will be enough shaft remaining of screw to turn out with small vise grips/pliers. Guide below may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Remoção de parafuso espanado
Esta resposta foi útil?
Pontuação 2
4 comentários:
but if i remove the head with a drill how im gonna take the rest out of the hole?
por Compartilhar
@pydev, Nick, That is where the problem could become difficult again, if all else fails, drill carefully just enough for screw head removal and hopefully there will be enough screw shaft to grab with small vise grips/pliers to turn remaining portion of screw out after board is removed. Good luck.
por Compartilhar
After you cut the head off and remove the board, the stub will be sticking out. Use something like this to grab it and turn it out: Screw Extracting Pliers
por Compartilhar
Thank you all hope it goes well
por Compartilhar
I have the same problem trying to get my ps3 super slim HDD out of the enclosure
I did everything but I have no. Dremmle
Pontuação 0
Adicionar a sua resposta
[deleted] será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 10
Últimos 30 dias: 31
Ao todo: 12,305
