Ir para o conteúdo principal
The Lenovo 100s chromebook-11IBY is an 11.6'' laptop featuring a 1366 x 768 display with up to 8 hours of battery life.
5 Perguntas Visualizar todos
How can I upgrade storage?
I have a Lenovo 100S Chromebook, serial number LR04HMFR if you need it, and I was wondering if I could, how would I go about upgrading my 16G storage to something like 120G.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
The hard drive for this device is actually soldered directly onto the motherboard. Unless you are very skilled with a soldering iron, it will not be easy to remove. I highly suggest simply just investing in an external hard drive if you are looking for more memory to store your files.
Esta resposta foi útil?
Pontuação 2
step 1 undo the screw on the back
Step 2 gently remove the hard drive (it is silver)
Step 3 Unplug the cable from the hard drive
Step 4 put new hard drive in a reconnect cable
step5 put screw back in
step 6 you're done
Pontuação -1
1 comentário:
No, impossible on this model, the memory is a chip soldered to the mainboard.
por
Adicionar a sua resposta
Olivia Williams será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 1,439
