Why is it so slow to charge
It take 8 to 12 hours to charge
Esta é uma boa pergunta?
dustyrob456, Possibly faulty battery/connection, weak charger or perhaps loose/dirty or damaged charge port. Look in the charge port and blow/pick out(carefully) any dust/debri that may be causing an issue also look in the port for any bent pins and straighten very carefully with a tooth pick. Try a different compatible charger/cord to see if that is the issue. If different compatible charger/cord does not fix and port looks/test good, the battery or connection could be bad, if able to clean battery connection(Qtip dampened with 90%+ Isopropyl Alcohol) and reconnect/install battery, still not charging battery probably faulty. Below is a guide that will get you access to battery, connections and enable you to check for other possible loose/bad connections and components. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,386
3 comentários
Could you take a picture of the sicker on the power supply?
Adicionar imagens a uma pergunta já existente
por George A.
It has no sticker on it sorry
por dustyrob456
Is it a USB power adapter? If so, does it specify the amperage? Such as 1A, 2.1A?
por George A.
