Ir para o conteúdo principal
The Xbox 7MN-0001 Wireless Controller, was manufactured by Microsoft Corporation. It is the first generation Xbox One controller released, but has since been discontinued. This controller has since been superseded by Models 1697/1698 and Model 1708. While this controller is commonly used with the Xbox One, it can also be used for PC gaming.
How to fix triggers on an Xbox controller?
Both RT and LT are not being recognized. I am using the controller with a PC and just changed out a couple of the buttons. I am pretty well versed when it comes to soldering etc and everything appears to be in place, and all other buttons/bumpers are working correctly. The triggers were working correctly prior to changing the buttons. I do not know what I screwed up. Thanks for your help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
You must have bumped the conector for the triggers when you changed the buttons. Open er' up and check em'. Click the picture of the remote next to the question to access the guides for it.
Hope this helps!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Tina Nagle será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 915
