Ir para o conteúdo principal
The Samsung Gear S3 is the third-generation Samsung Gear smartwatch, first released in November of 2016. Features a round OLED display running the Tizen OS. Model number: SM-R770NZSAXAR.
20 Perguntas Visualizar todos
The four back screws
i want to open the back of my samsung gear s3 but i do not know if the back screws are tri-point type or tri-wing type? also, i want to know the type and size of the screwdriver that can turn these screws. please help!!!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Hey I will like to know where I can buy four rear screws for my gear s3 classic
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi!
The screw type is a tri-point Y0. You can get the screwdriver in the 64 bit driver kit from the ifixit shop.
Esta resposta foi útil?
Pontuação 1
1 comentário:
would you happen to know the size of the screws? I stripped one and need a replacement. thanks.
por
i have the samsung gear 3 as well. I tried to remove the 4 screws in the back. 2 came out perfectly and the other 2 are now stripped. Any advise on how to remove the stripped screws?
Pontuação 0
Adicionar a sua resposta
rolando de la rosa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 16
Duração total: 7,941
