T3 won't stay on.
bought a T3 for Christmas and it turns on, but won't stay on if you take your finger off power button. Any easy way to fix? Paid a lot for it to not work after 4 months.
Esta é uma boa pergunta?
dzinegrafix, Could be a bad power button, loose broke wire/component or bad board. May still be warranted and if it is contact the manufacture for repair/replacement/refund. Below are a couple links that may help in disassembly of T3 and enable you to trouble shoot switch/connections/etc.. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Esta resposta foi útil?
I know this is an old thread, but I had the same problem. Did you ever find a solution? I tried swapping out the power button, but that didn’t work.
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 2,641
