Ir para o conteúdo principal
The Venue 8 is a midrange Android tablet, released by Dell in 2013.
Where is the HDD located on a Venue 8
Disassembling a Venue 8 5120 for Recycling and I wanted to remove the HDD to destroy it and I cannot seem to figure out what part is the
HDD
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Tablets usually have an "HDD" soldered on to the board. Unfortunately, unless you identify the storage chips on the PCB, there isn't a physical "HDD." It is rare to find a replaceable/upgradable storage drive on a tablet.
More appropriately, it might as well be called an SSD, but still.
If you can boot it up and trigger a system reset so that it clears the onboard storage and returns to factory default, you shouldn't need to worry about it. Otherwise, take a stab at random chips and see which ones hold the data.
Esta resposta foi útil?
Pontuação 1
This image is from dell venue 8 pro.. but the chip is an BGA-153 on ailexpress. have not hear if anyone has upgrade it or not..
Pontuação 0
Adicionar a sua resposta
Denom Krall será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Ao todo: 1,739
