Ir para o conteúdo principal
Released October 24, 2011 / 2.2, 2.4, or 2.5 GHz Quad-core Intel Core i7 Processor
405 Perguntas Visualizar todos
Device booting to black screen
I restarted my macbook and just after the apple logo appeared there were some flickering lines on the screen and then just a row of vertical red lines. I turned it off and attempted to reboot it but now all that happens is the optical clicks and the front indicator light comes on. Otherwise it's just a black screen, no boot tone.
I attempted reseating the RAM, both slots, a PRAM, SMC reset, and manually removing the battery. I also booted it with no RAM in it and got the beep tones so I believe my logic board is alive.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Logic board has failed - based on the vertical lines and unable to boot.
Check out the last paragraph of this page: https://www.apple.com/support/macbookpro...
The late 2011 15" have known logic board issues and actually had a recall on them. Might be worth calling apple and seeing if they will replace it still even though they ended the program.
Esta resposta foi útil?
Pontuação 2
2 comentários:
It was discovered a tantalum capacitor was degrading that was the root issue. Apple placed it too close to the GPU so it tended to cook a bit. Review this answer: Problem with NVIDIA GeForce GT 330M 256 MB?
por
Interesting. Thanks for sharing!
por
Adicionar a sua resposta
Dirk Gunderson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 421
