Upgrade CPU iMac 27" early 2011
Are there any restrictions which CPU i could use? Would a i7 4790 work?
Esta é uma boa pergunta?
Sorry there are limits on what will work. The best you can put in is a 3.4 GHz Core i7 (I7-2600)
The chips are very different TDP & needed socket
As Mayer stated we might be able to offer some guidance on how to make your system run better. Can you tell us what your current CPU, memory & storage is. It would be helpful knowing what you are doing as well.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 1,434
1 comentário
What's your end purpose? What CPU do you have now? Are you trying to speed it up? If so please tell us your RAM configuration and hard drive/s set up and we may be able to give you some suggestions that we've actually tried.
por mayer
