Ir para o conteúdo principal
Transfer to iPhone 6plus
I have an iPhone 5c with a sim and I want to upgrade it to an iPhone 6plus which is not new . The iPhone 6plus has all the apps that I want but It doesn't have a sim . The sim I want to put into it is in the iPhone 5c. Do I have to take it to iplanet or can I do it ?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
Hello Raageshwari ,
Simply you can do it your self, just connect your iPhone 5C to iTunes and get backup and restore it to iPhone 6+ . sim card is required for the carrier unlock not for the data transfer.
Hope this answer help you to migrate your personal data and apps to iPhone 6+
Esta resposta foi útil?
Pontuação 3
If you have a computer, simply back up the 5c to iTunes.
Then restore the iTunes backup to the new 6+.
You will then go to Settings --> General --> Reset --> Reset all settings.
Pontuação 1
To reach it, you need to turn to a professional 3rd-party program - iOS Transfer. With it, you can simply plug your old and new iPhone into the computer at the same time, and select the needed moved data like contacts, text messages, photos, apps, etc. for transferring between iPhone devices selectively or in a batch as you like. And you can also choose to export data from iPhone to computer, iTunes library or other devices without restrictions. Furthermore, this tool can also help you manage your iPhone data like add, delete, edit, etc. contacts info on PC directly.
Pontuação 0
Adicionar a sua resposta
Raageshwari será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 97
