Static issue on iPhone 7?
After applying anti-static conductive paste on the iPhones 7 screen it stop working. It looks like it shorts it out or the flex is damaged.
Any suggestions ?
Esta é uma boa pergunta?
Any suggestions ?
If you are getting a green screen during usage (static), leave it unplugged for a while and it will resolve itself. If you are getting purple marks wherever you touch the screen, it is probably a bad quality polariser. If the touch stops working completely, you may have slightly damaged the ribbon or the edge of the digitiser (corner or side may be missing/have small fracture).
Esta resposta foi útil?
Hi, if I fail to use conductive paste would this lead issues including unresponsive Fd touch not working and temperamental touch, though the lcd displays peeferctly?
I find this a lot on the iphone 7 screens.
They are tested ok before refurb and afterwards they don’t.
What is the actual purpose or use of conductive paste?
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 1,062
1 comentário
I know that at least refurbishing iPhone 5 series screen requires it.
iPhone 6 you can get away with not using it but not 100% sure on iPhone 7 probably the same thing.
Have you tried a using touch screen without the anti-static conductive paste (though it may have issues without it while charging)?
por Ben
