Ir para o conteúdo principal
Echo SRM-225 Trimmer. This model replaced the SRM-210. The most common repairs for this device are straight forward and can be done quickly.
I change the spark plug, air filter and fuel filter stil do not start
I put a new tune up kit for my echo srm 225 still not start
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
How old is the trimmer? I have seen the fuel lines go bad over time and have a pin hole in it that causes issues with the fuel feed.
Esta resposta foi útil?
Pontuação 0
It's usually a pin hole in a fuel line, primer bulb, and sometimes there is one in the diaphragm. It could also be a bummer up carb. Try cleaning it through the filter housing with carb cleaner.
Pontuação 0
Adicionar a sua resposta
firstknight97 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 567
