Ir para o conteúdo principal
Echo SRM-225 Trimmer. This model replaced the SRM-210. The most common repairs for this device are straight forward and can be done quickly.
Have replaced all basic and fuel will not run with out choke
I have changed out on echo srm 225 weed eater spark plug, fuel, air filter, fuel filter it will start with full choke but soon you start to turn choke down will stall out and also will not idle up when giving it throttle up speed does not change
Esta é uma boa pergunta?
Pontuação 1
1 comentário
changed fuel, carb twice, checked spark arrestor, did I mention this weed eater is only a couple of years old and used very little. changed spark plug, twice, changed all tubing including fuel filter, changed air filter twice. What's wrong with my weed eater (SR 225)?
por
Adicionar um comentário
2 respostas
Solução escolhida
@rebel1,David, A couple things to check for,Good/fresh fuel proper mix, loosen gas cap and see if engine runs better, if runs OK the vent in the fuel cap is clogged. When fuel filter was change did it fall back to correct position(laying at bottom of tank) or did it get hung up staying upper level of tank(not fully submerged in fuel). Remove spark arrester from muffler and clean(when clogged the engine will perform in this manner) link below show method, If still no go possible dirt in carburetor/weak diaphragm/hole in fuel line or pinched. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
https://www.youtube.com/watch?v=U0LJ3gX2...
Esta resposta foi útil?
Pontuação 3
did all that and still have the problem
Pontuação 0
Adicionar a sua resposta
David Rickert será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 16
Ao todo: 6,798
