GameCube Controller not responding got it two days ago
Just need some help fixing my controller it seems to not work anywhere but my other one works fine.
Esta é uma boa pergunta?
Are any of the wires inside the wire casing broken? This tends to happen to second-hand controllers, especially if the wires where wrapped around the controller to tight during storage.
Esta resposta foi útil?
something you can do to trouble shoot the wire is take a multimeter and your controller open up the controller hold one of the pins on the gcc port
make sure you are only in contact with one pin on the multimeter then on the circut board test each socket that the cable plugs into there should be 6 while testing each port you should hear 1 beep per gcc port socket if you hear to then you have some wires crossed if you dont hear 1 then you have a weak connection or cut cable
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 571
Where did you get it from?
Did it ever work?
Does the cable or the controller itself seem to have damage?
por Conor Bailey
