Ir para o conteúdo principal
Should the rough side or the fluffy side face against the airflow?
I bought an electrostatic furnace filter pad. It s just a sheet of material that need to be cut to the size of the air duct. I m not actually using it for a furance - I m sticking it into the air outlet of my dryer machine since it vents indoors and I m trying to reduce the amount of lint that spits out of the machine. This filter pad has a rough side and a soft/fluffy side. Does anyone know which side should be oriented against the airflow? That is, which side should be the "blowing" (not the suction)...?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi mckenziemardelli, the fluffy side should probably face the inside of the air outlet so that the air hits that side first. You can read this for more info.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
mckenziemardelli será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 66
Duração total: 2,173
