Can I remove power steering pump pulley on my jeep 1999 cherokee
Can power steering pump pulley be removed without disconnecting power steering hoses?
Esta é uma boa pergunta?
rob welsh, I believe you should be able to remove the pulley with out removing the hoses. 1st Link below has some info. and type of puller/installer kit required which may be available as a loaner tool or rental fee from local parts store, 2nd link shows a pulley being removed(may not be your exact vehicle) shows the motions. Belt naturally will have to come off and the fan shroud will probably have to be removed. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 2,068
