Ir para o conteúdo principal
Model A1347. Released on July 21, 2011. Core i5 or Core i7 Processor. Thunderbolt. This unit is also used to run the Mac mini Server configuration.
How to remove stripped logic board screw?
I recently followed the guide on replacing the hard drive in my mac mini.
I ended up being successful, however in attempting to loosen the logic board screw to allow room to to seat the hard drive as the instructions indicated, the screw was so tight I stripped the screw. After quite a lot of struggle I seemed to get the drive seated and it is functioning.
Is there a way to loosen the screw for any future issues?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
If you have some of the head left then you can try and apply more pressure and turn the driver slowly.
If it is completely striped, then your options are pliers or drill.
If you can get needle nose pliers on the head and have enough grip to turn it, turn slowly, and be careful not to scrape the board.
You can also use a drill with a drill bit as close to the same size of the screw as possible and apply some, not a lot of pressure, straight down and use the lowest speed to slowly drill the head away, once the head is off you can remove the rest of the board and use pliers to remove the remaining screw.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thanks . I think I will wait until I need to attack that project if I have to.
The drive is installed and working as of now .
por
How to Remove a Stripped Screw
Theres a great guide on a few ways to do that.
Pontuação 1
1 comentário:
Impact driver set works well too. But that is last resort before going to cutting tool.
por
Adicionar a sua resposta
b biggs será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 656
