Ir para o conteúdo principal
Sony ICFC1T alarm clock/radio is manufactured so that in the event of a power outage, you have the peace of mind that your device will continue working so you never miss an event.
12 hour format instead of the 24 hour?
Does this model come with the 12 hour format instead of the 24 hour.
Esta é uma boa pergunta?
Pontuação 3
3 comentários
Tough one... The user's manual does state that the radio uses a 12 hour clock, but I read 3 reviews that both stated that the clock uses the 24 hour format.
por
I purchased ICF-C1 from Harvey Melbourne. It cannot change the time format to 24 hrs
por
any one can guide me to change the time format to 12 Hr
por
Adicionar um comentário
2 respostas
Solução escolhida
https://docs.sony.com/release/ICFC1.pdf
That might be of use.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thank you! Very helpful. I am from the UK and after a little research I found out that the 24 hour format is for UK clocks and the twelve hour ones are for America manufactured clocks. I prefer twelve hour, so I will just order it online from America instead
por
But isn't there an option for both of them for switching the time format from 12hour to 24 hour and back?
Thanks
por
I wouldn't. America uses 120v whereas the UK uses 230v.
Pontuação 0
Adicionar a sua resposta
Sam Melrose será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 79
Ao todo: 11,414
