Ir para o conteúdo principal
A rugged chromebook designed for educational use with reinforced ports and hinges, anti-peel keys, a sealed touchpad, and 9.5 hours of battery life.
Cannot open the laptop to change internals
Even when I have removed all the screws on the bottom of the laptop, I am still unable to open it. It seems stuck around the corners and I am afraid that if I try to force it I'll end up breaking it. It feels like there are more screws but I can't see any.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Have you removed the screws under the rubber feet?
Esta resposta foi útil?
Pontuação 1
2 comentários:
Yea there is 4 screws, one under each foot.
por
There are 10 screws on the bottom in total
por
Check for screws under those little squares or circles not just the feet. If done you just gotta pry it.
Pontuação 0
1 comentário:
They are the feet.
por
Adicionar a sua resposta
Jacob Taylor será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 458
