Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Battery replacement every 2 months
Hi,
I have an iPhone 5s for now 3 years and a half. The original battery lasted as long as 2 years and a half before dying, so I then replaced it by buying new ones on the Internet.
However, the new batteries I bought (3 or 4 for now) only last 2 months before dying too, so I got to replace them quite frequently.
During the first month of use, they usually work great and have a good capacity, but by the second month, their capacity drop very quickly and my iPhone doesn't start anymore.
Do you have an idea on the cause behind this? Could it be the logic board that is getting dysfunctional and draining the batteries very fast? Or am I just buying bad batteries?
Everything else works fine on the iPhone, I even tried a reset to make sure it wasn't iOS's fault but it didn't change anything.
Should I consider my iPhone dead or is it possible I only got bad batteries?
Thanks for your help :)
Esta é uma boa pergunta?
Pontuação 0
10 comentários
There are 2 things. Either your iPhone is dead. Or the batteries your getting are very cheap. How much do you pay for the batteries?
por
Usually around 20 bucks each
por
Do you buy them from the same person? Or different sellers?
por
A better question is, where are you purchasing them from?
Have you tried an iFixit sourced battery?
por
Yea, they are 15 bucks at ifixit, for a genuine battery. Your getting ripped off.
por
Exibir mais 5 comentários
Adicionar um comentário
2 respostas
Solução escolhida
I would suggest a genuine iFixit battery.
How to replace the battery in your iPhone 5s
iPhone 5s Battery
If this answered your question. Please hit the accept answer button!
Imagem de iPhone 5s Battery
Produto
iPhone 5s Battery
$29.99
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
I would recommend using the ifixit battery since they are genuine. You never know with other re-sellers what quality battery you are getting and that is most likely the problem. I have pasted the link below to the part. I hope this helps!
iPhone 5s Battery
Produto
iPhone 5s Battery
$29.99
Pontuação 3
1 comentário:
@luffy343, the only way to get a real Apple battery is to go to Apple. Any other source is a 3rd party. However, iFixit has accountability as opposed to other sellers.
por
Adicionar a sua resposta
Ottomatik será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 144
