Ir para o conteúdo principal
A backlit keyboard/case from Logitech, made for the iPad 12.9 inch model.
3 Perguntas Visualizar todos
sometime logitech create keyboard12.9doesnt work
when I use it to type.it doesn't work sometime.just for seconds.i don't know reasons,but I want to take the Logitech keyboard apart.but I don't know how to.can you tell me,thank you.i like your team.im a middle school student from China. thank you so much .
Update (05/08/2017)
it is Logitech create ik1200 keyboard for ipad pro 12.9.thank you
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Have you re-booted the ipad?
Are the little connection pins making good connection?
Are the pins clean and free of debris?
Let me know if this helps.
Esta resposta foi útil?
Pontuação 2
1 comentário:
On mine, it’s always poor contact between the 3 pins on the case and the iPad. Lift the assemble by the center of the top long side, then set down on a flat surface. Mine always starts to work.
por
Adicionar a sua resposta
shanhao será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 644
