Ir para o conteúdo principal
A baby monitor made by Infant Optics, Inc. The DXR-8 features a 3.5" screen , temperature sensor, night vision, and an interchangeable lens system.
Can you recalibrate the thermometer?
The thermometer/temp reader used to be very accurate, but now seems to be showing a high temperature compared to what the actual room temperature is. Is there a way to re-set it or recalibrate the thermometer?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
@camillelynn I read through the manual. There is no reset option or reset button.
What I can suggest is completely disconnecting the battery and wait a few minutes and reconnect the battery. Maybe whatever miscalibration will reset in this manner.
They have a dedicated help line at info@infantoptics.com which may be able to let you know if this is a hard ware defect or simply a reset fix.
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thank you for your thoughts! I'll give that a try.
por
Did this work? It doesn't work for me, and the temp has never been right. I just now figure that it's always a few degrees cooler than what it actually says. But that's frustrating.
por
I have a different issue.the temperature moves up and down from the top to rhe botton.After that, stops and shows a doble H H and the celsius or farenheit symbol . Any suggestion? Thanks
Pontuação 0
Adicionar a sua resposta
Camille será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 106
Ao todo: 21,994
