Ir para o conteúdo principal
Why does the washer drum tilt toward the back of the unit?
the washer drum tilts toward the back of the unit and causes a gap between the drum and the seal. could this be due to bad springs. i have already put new shock absorbers in as the old ones were bad. not sure where to check next.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Yes. The springs are worn. Replace all of them at the same time.
Esta resposta foi útil?
Pontuação 4
1 comentário:
bullshit! pure Bullshit
por
If you have a front load washer, the tub bearing and spider gear could have failed. That is an expensive and difficult repair.
Pontuação 1
1 comentário:
It's really not that difficult. Plenty of videos on how to do it. If you are a woman you may need the assist of a man to help.
por
I installed new springs ...no joy
Pontuação 0
1 comentário:
No joy? Is your washer a top load or front load? Please include the washer make and model number.
por
Adicionar a sua resposta
nea.s.miller será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 27
Duração total: 3,012
