Ir para o conteúdo principal
The Samsung Galaxy Tab S 10.5 released in July 2014 is a 10.5” Android tablet with a 2560x1600 pixel resolution, 16GB of storage, and 8.0MP camera. Model numbers: SM-T800 (WIFI), SM-T805 (Cellular and WIFI)
Device is not charging
I had a problem with this tablet either charging extremely slowly or just not at all.
I have tried multiple charger which all charge my Samsung Note 4 without a problem.
I have now replaced the battery and charging port but I am still having the same issue.
If I plug it in while turned off I get the charging screen, it shows 1% but does not go past this, I can turn it on and it will say it is charging but will not go past 1%. Occasionally when it is turned on there is a red cross over the battery, this does not always appear.
I would greatly appreciate any new suggestions.
thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I can't tell you 100%, but if you have replaced the battery, port assembly and things like that, I would guess that the issue is with the Logic Board. However, it couldn't hurt to re-flash the firmware, as Android can cause weird issues sometimes. Hope that can help.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ben Gray será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 446
