Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
I broke the home button to iPhone 7 internally
I am replacing an iPhone 7 screen and have not done one of those yet. There is another cord on the side of the phone that I did not see which is the home button. I didn't see if. And I broke it. Do u know where to find that piece?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
If it's the cable that directly comes and is connected to the home button itself then you can't just replace it as it will not function at all.
Apple is the only way at the moment to get the home button to work again (They will probably charge you a screen replacement).
Esta resposta foi útil?
Pontuação 2
If you broke any part of the home button, you must take it to Apple in order for you to have Touch ID and physical home button functionality back. The home button is "married" to the logic board, therefore there is no way to replace the button and expect to have any functionality.
Pontuação 0
Adicionar a sua resposta
Emily será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 112
