Ir para o conteúdo principal
Repair information and support for walk-behind lawn mowers made by the Toro Company.
20 Perguntas Visualizar todos
White smoke out of muffler once warmed up
My Honda engine on a Toro motor suddenly started billowing white oily smelling smoke out of the muffler. I shut it down, and let it sit for a while. it starts on the first pull, runs fine for about 20 minutes and then starts billowing out white smoke again.
Head Gasket?
Esta é uma boa pergunta?
Pontuação 3
2 comentários
Mine is 2 yr old new log splitter engine. Oil looks clear and up to line . Worked well past hour then quit grrrr
por
My Toro did that yesterday. I had been mowing for about an hour, stopping when needed to empty the bag. But this time, it started billowing white smoke out of the exhaust. It's only two years old.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Blue or white smoke coming from your engine usually indicates burning oil, which can be caused by:
Overfilling the crankcase with oil
Incorrect oil grades
Operating engine at greater than a 15 degree angle
Inoperative crankcase breather
Crankcase air leak
Blown head gasket
Worn cylinder and/or rings
Turning/tilting the engine on its side for storage, oil change or any other reason.
Note: If the engine has to be tilted, ensure the spark plug is facing upwards to help prevent oil from escaping the crankcase.
Other reasons for blue or white smoke from engines include exceeding the engine’s oil capacity shown on dipstick, an obstruction in the breather tube (located behind the air filter), damages to the cylinder/piston rings, and more.
Engine oil capacity is dependent on your specific engine model and can be determined by checking the Oil Recommendation FAQ. You can also learn how to check the oil level and change intervals to ensure the engine is running at the correct oil capacity.
How to Troubleshoot Engine Smoking
If you wish to troubleshoot and repair the small engine yourself,
Step 1: Are you tilting the engine or using it at more than a 15 degree angle? Tilting your mower or equipment can cause leaks. Right the machine before moving forward.
Step 2: Checking and changing the oil is an easy troubleshooting technique for this problem. Check to see if the oil is overflowing or you’re using the wrong grade/type.
Step 3: Check the crankcase for leaks.
Step 4: Is the head gasket blown?
Step 5: Are the rings and/or cylinder worn?
Esta resposta foi útil?
Pontuação 2
I have a brand new Toro doing the same thing. Runs great then all the sudden it just billows white and blue smoke. Run it for a bit and it comes out of it. Mowed four days ago, no smoke, mowed today got about half way done and poof I filled the neighborhood with smoke.
Pontuação 0
2 comentários:
Would love to see the answer. This is what my Aunt's mower is doing. Acts like it's running out of gas, blows blue smoke, then clears up and runs normally
por
My brand new mower is putting out a cloud of white smoke every 10 min, oil level fine, oil grade fine, etc. Engine feels very hot. When the cloud of smoke starts, I stop the mower and it works fine again for another 10 min, the huge cloud of white smoke again.....very frustrating since I took it to repair under warranty and they could not find anything wrong.
por
Adicionar a sua resposta
a.catanzarite será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 42
Ao todo: 42,048
