google play service has stopped
do i do a clean install?
Esta é uma boa pergunta?
Douglas L'Abbé this video may help its for aany app that throws the error you mentioned
https://www.youtube.com/watch?v=LZ7eOLpJ...
Hope it helps
Esta resposta foi útil?
Try to format the cache partition first:
You should begin by turning off the device using the Power key.
Then, hold down Volume Up + Power button for a few seconds.
Release held keys as soon as you see the Android Robot.
To enter the Recovery Mode hold down the Power key for a short while.
You should see the Recovery Mode menu.
Use the volume up/down to move up and down the menu. Power button selects
Choose 'wipe cache partition'
Select yes on the next screen
After a wipe, choose 'Reboot system now'.
your device needed to flash.
@asimqasim explain what you mean by flash
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 927
