Install SSD Disk on Mac Pro Early end 2009
Hello, i need install an SSD Disk 3.5" in my Mac Pro Early 2009 (Xeon Nehalem)
Esta pergunta é pertinente?
Use one of these to convert your 2.5" SSD (if it is 2.5") into a 3.5" and then depending on your model, follow the instructions that apple gives to replace the HDD with a SSD or just add it on. Then install OS X on it so it will boot up from the SSD and no tthe HDD.
Esta resposta foi útil?
The ICY frame is not needed for SSD's. Use this instead its cheaper!
OWC 2.5" to 3.5" Drive Adapter Bracket
If you need a spare Mac Pro drive tray (Sled):
The OWC 2.5" to 3.5" Drive adaptor bracket will not work for Mac Pro because the alignment is different!
Add any 2.5" Hard Drive or SSD to your Apple Mac Pro!
While designed with the OWC® Mercury brand SSDs in mind, the OWC Mount Pro 2.5 is the easiest way to add ANY 2.5" Hard Disk Drive or Solid State Drive to your Apple Mac Pro (2009-Current 'Nehalem' & 'Westmere' models).
The powder-coated aluminum and open design assists in heat dissipation while the blue color not only looks sharp, but allows you to tell at a glance which bays contain 2.5" form factor drives.
Installation is a breeze. Simply attach your 2.5" drive to the bracket using the four included hard drive mounting screws and swap with an existing 3.5" drive tray. The OWC Mount Pro 2.5 perfectly aligns the SATA connection from your 2.5" drive into the back plane SATA ports on the Mac Pro.
Note: Not for use with Mac Pro models released in 2006, 2007, or 2008
Warranty: OWC Limited Lifetime Warranty
That was also my solution. It has worked great for over three years now, and no issues.
Agree with DenisCmdr. Yesterday, I installed a 250GB Samsung SSD into my Early 2009 Mac Pro, running Mavericks OSX, using the OWC Mount Pro 2.5 adapter. What an installation breeze. I put the old WD hard drive into an external enclosure, and installed the new SSD (in the Mount Pro 2.5). I then followed the latest Apple Knowledge base information about backing up and using the Migration Assistant Utility. OWC also has some good technical advice on doing reinstalling the OSX and the file transfer.
https://eshop.macsales.com/tech_center/f...
I do not understand why the Apple store they sell a replacement kit for Mac Pro SSD but only for Mac Pro built in mid-2010.
Someone told me that I would burn the SSD Disk with my Mac Pro (early end 2009) because it lacks the technology to fully exploit, is that true?
Not true.. as long as its SATA, it will work.
Half True ;-}
The real issue is the systems SATA ports speed and what you install need to match. Make sure you review EveryMac listing for your exact system to find what the SATA port speed is of your system. Then review the spec sheet of the drive you are think on using. Is your systems SATA port data rate listed? Some SSD's only offer a fixed SATA I/O speed, some only offer SATA II (3.0 Gb/s) & SATA III (6.0 Gb/s) compatibility, and others all three SATA I (1.5 Gb/s), SATA II (3.0 Gb/s) or SATA III (6.0 Gb/s).
As an example: Many of the first gen Mac Pro's only have SATA I (1.5 Gb/s) HD ports.
So if you put in a FIXED SATA III drive it won't work or even a dual speed drive SATA II & SATA III still won't work! You need to use either a FIXED SATA I or one that auto senses the systems SATA port and can run at SATA I speed.
Here's a more hacky solution.
I have a 2008 Mac Pro and a Crucial RealSSD 2.5" drive. I didn't have access to a 2.5" to 3.5" adapter, nor anywhere to buy one easily. I simply installed the SSD drive 'bare' in hard drive slot 1 by pushing it into the SATA connector at the back and then supporting the drive with a small object underneath it. The small object sits on top of the grey box underneath hard drive slot 1 (fan assembly?). In my case a small box of staples was just the right height to keep the SSD drive perfectly straight.
This is probably a risky way to install it since if the drive comes in at an angle it might ruin the SATA connector from stress in the plastic. But it works for me for now.
You can also try this.
You can build your own SSD support.
.. Woah O_O thats intense
Ok how about this hack for an SSD in the mac pro. Install it in the DVD burner cable no need for any adaptor
I use ICY DOCK MB982IP-1S in my 2008 Mac Pro for installing SSD into my Mac.
You don't need an ICY dock as SSD's run cool.
These where only needed with high RPM 2.5" platter drives (HD's) which need more cooling.
Just wasting your money & adding extra weight
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 10
Duração total: 19,825
Nice postIf you are looking for an online homework helper that is gentle to your pocket . Your best home work expert is here.visit our blogs at Pinoy Ako Tv, Pinoy Tv Replay, Pinoy Tambayan, Pinoy Tv Show, ABS-CBS Tv Show All HD Quality ,GMA Show,Full Episode Watch On PinoyTvShows.Our team at Pinoytv care for our community and bring you daily fresh episodes of your favourite tv shows. You can enjoy your favourite shows, Pinoy Tambayan, Pinoy Teleserye
Pinoy Channel
Pinoy Tv Replay
Pinoy Lambingan
Pinoy Teleserye
https://thepariwiki.com
por Najeeb Mirani official
