Can I add an HDD 2.5 or SSD?
Hello,
I am looking to buy an XPS 15 (9560), but I would need more memory than 512Gb.
Could I add an internal HDD?
Regards
Ricardo
Esta é uma boa pergunta?
Hello,
Regards
Ricardo
Ricardo, it looks as if you can add a 2.5" HDD or SSD. The factory SSDs are in a M.2 or mSATA slot, leaving the HDD bay open for upgrade. You may want to consider a Seagate firecudas SSHD for not much more than the price of a regular HDD.
Hope this helps!
Esta resposta foi útil?
Here's a guide for doing it:
This is only possible on the version with the smaller battery. The version with the 97Wh battery has no room for a 2.5" drive.
Source: I own both version
yes you can up to 1TB
I would like to know where you got this information.
Yes you can if you have an FHD model. Consider that you'll need an adapter. You can easily find it online
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Ao todo: 8,768
1 comentário
you are asking two questions. or you may be confused on parts. first memory is not the same as a hard drive. so are there two questions or just one?
por altbell
