Ir para o conteúdo principal
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
New digitizer is not working
Just installed new digitizer/glass purchased from iFixit. New screen is not recognizing finger touch. Help!
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
The only thing I can recommend is to double check the connector is properly seated in its slot. Sometimes it's a bit hard to push it in the right way. You can verify if after you lock it in place it offers resistance if you gently try to remove it or just slides out easily.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Greg Horrocks será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 84
