Ir para o conteúdo principal
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
83 Perguntas Visualizar todos
Will not turn on, no image on the screen.
will turn on, theres a green light indicator but no image loading on the screen, tried removng batterry and resetting by holding power button but wont do, when try to remove and re insert battery, green light indicator automaticaly turn on w/o sliding the power buttton on
Esta é uma boa pergunta?
Pontuação 5
1 comentário
franklyn72001, did you get it fixed?
por
Adicionar um comentário
2 respostas
Pergunta mais útil
try to turn your psp on using charger and if you can connect it to a tv and see if the display turns on if it does then take it off display and if its still black screen then that means you have a backlight fuse problem.
Esta resposta foi útil?
Pontuação 1
buy a new battery
Pontuação 0
Adicionar a sua resposta
franklyn72001 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 5,194
