Ir para o conteúdo principal
O Nintendo 2DS é um dispositivo portátil de jogos desenvolvida como uma versão de nível de entrada do Nintendo 3DS com hardware quase idêntico, mas sem a função de ecrã superior 3D.
205 Perguntas Visualizar todos
SD Card Stuck In Write-Protection (Console Problem)
Hello,
i am having a problem with the console saying the SD card is stuck in write-protection. i can tell you for a fact, the card is not. the slide is at the top and have even tried 2 other SD cards. The other SD cards i have also work fine in another 2DS i have tried.
are there any suggestions how how to fix it? i updated the console and formatted it just to see if that would fix it.
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Try to open up and clean the contact pins, they could be dirty and shorting something out.
Esta resposta foi útil?
Pontuação 3
5 comentários:
Thanks for the reply, i gave it a shot but to no prevail. nothing is screaming out at me that there is anything wrong visually
por
What about the 2 smaller pins to the side?
por
they appear to be fine, not touching each other
por
What about cleaning around the connector? Also has it ever been water damaged?
por
yeah ive cleaned it. it was all clean already but gave a clean as best i could just in case. there is no liquid inside. no visible sign of water damage
por
Adicionar a sua resposta
James será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 3,198
