Ir para o conteúdo principal
An Android smartphone produced by Huawei, released in April 2015.
30 Perguntas Visualizar todos
Can I fix a broken screen at home?
I have broken the screen of my Huawei P8, quite harshly... Is it possible to fix this myself(at a low cost) instead of sending it to a professional repairplace? If not, do you know where I can go to fix this? And how much it will cost me?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Hi Inga,
It's work, it would feel challenging to a first timer - but it's not something you should shy away from if you feel up to the task. The monetary savings can only be compared to what your local repair shop would charge you.
Here are some things to consider, an electronics tool kit such as the one sold by ifixit is very helpful, and at a minimum, a screwdriver kit and some kind of prying tool is needed. This guide below is for the P8 Lite, but it will give you a good idea of the work involved to take it apart:
Huawei P8 Lite Teardown
ifixit also sells the screen replacement you need at $55+shipping:
Huawei P8 LCD and Digitizer
If you have absolutely no tools, it might be cheaper or close to same cost to pay for repair service locally. However, the toolkit is forever, and so is the experience.
I hope this helps to give you a general idea of what it entails
Imagem de Huawei P8 LCD and Digitizer
Produto
$9.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Inga Katrine Vold será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 7
Duração total: 1,253
